How Much Fuel Is Left.....Low Fuel Warning On
Old 12-04-2017, 10:12 AM
Marc's Avatar
Member
Default How Much Fuel Is Left.....Low Fuel Warning On
Pertaining to the low fuel warning light on the 2015 CRV........when that light turns on, how much gasoline is really in the tank?
Old 12-05-2017, 02:58 AM
most honda's have approx 2+ gallons left when the fuel light comes on. only real way to check is to have a 2 or 5 gal tank of spare fuel and run the tank dry, but be aware if you run out of fuel and leave the key on, you will burn up your internal fuel pump, this will be very expensive to replace in the tank.
Old 12-05-2017, 06:56 AM
Marc's Avatar
Member
acmech52........Thanks for the info!
Old 12-05-2017, 05:21 PM
When your light comes on check the drivers information center,it will give you an approximate amount of miles left according to your miles per gallon.
Old 12-05-2017, 09:31 PM
Marc's Avatar
Member
Will do.
Old 12-10-2017, 08:59 AM
John Hollenbeck's Avatar
Default low fuel ind
Running with a low fuel light is not a good idea. If the pump is in the tank, the fuel is used to cool the pump. Secondly, dirt will be sucked into the fuel system. The light is there as a reminder you need fuel as soon as you can.
vipercarcom
07-19-2013 07:15 AM
Tregonsee
04-11-2012 07:54 AM
fredlp
11-24-2008 10:05 PM
Marc
11-22-2008 06:05 AM
proff
09-29-2006 09:28 AM
Quick Reply: How Much Fuel Is Left.....Low Fuel Warning On
