carb float cutoff adjust
nighthawk cb450sc 1982 rebuilt carbs but fuel leaks out of the air intake ports, I suspect the float needles are not adjusted right. any advise would be appreciated
With that age of a carbuerator Id definitely have it rebuilt or at least replace the needle / seats and bowl gaskets.. sounds like the floats may have absorbed fuel and sunk inthe float bowl.. or the needle valves are just shot.. either way a fuel leak on a bike is a dangerous situation..
Good luck! |
Originally Posted by HondaPartsConnection
(Post 28513)
Good luck! thnx, carb has been completely disassembled, cleaned and rebuilt with all new parts. I need float adjust, but saw now way to adjust on this carb...? |
