-   Cruising / Standard (https://hondaforum.com/forum/cruising-standard-23/)
-   -   CB250NE Battery Charge (https://hondaforum.com/forum/cruising-standard-23/cb250ne-battery-charge-1476/)
ol9finger May 2, 2007 02:45 AM
Hi all,
Just a quick question as it is doing my head in.
My battery refuses to keep a charge. I have replaced the battery, and there is about 13.4 V going into the battery when it is revved. After about a week tho the battery is flat.
Any suggestions?
Thanks for your help,
acmech52 May 2, 2007 06:36 AM
RE: CB250NE Battery Charge
may have a mild short, check to see if all your light bulbs are working, check wiring for draw. When you hooked up your battery terminal, and if there was a mild spark, then there may be a mild draw that should not be there.
