Element Forum This unique crossover provides the interior room of a minivan with the abilities of a compact SUV.
Honda element crank no start after replacing waterpump
Old Nov 20, 2023 | 08:21 PM
  #11
Junior221's Avatar
Plugs are all good. It started fine before water pump was replaced it just makes no sense that it wouldn't start after
Old Nov 21, 2023 | 10:35 AM
  #12
Yeah, it doesn't make sense. Maybe moving some wiring around broke a connection.
Anyway, did you check all the fuses? Just it case of something simple?
Old Nov 21, 2023 | 07:54 PM
  #13
Junior221's Avatar
Yep all fuses are good
Old Nov 21, 2023 | 09:33 PM
  #14
Well, I am sorry. I just do not know what else to look at.
May be time to go back to basics
Check for fuel
Check for air flow
Check for spark check for timing
Check for exhaust flow
Check for compression
ETC????
Old Nov 21, 2023 | 10:09 PM
  #15
You need to test not guess.
Old Nov 21, 2023 | 11:05 PM
  #16
Junior221's Avatar
No ****. I did test doesn't do me any good guessing
Old Nov 21, 2023 | 11:10 PM
  #17
Junior221's Avatar
Check for fuel
Check for air flow
ETC????
that is my guess. I'll have to go back to basics and test again. I set it aside had other projects to get to before Thanksgiving
Old Nov 22, 2023 | 09:24 AM
  #18
What KV is the spark at? Fuel pressure in PSI? Numbers NOT it's good.
Opps.
Old Nov 23, 2023 | 02:00 PM
  #19
Junior221's Avatar
Opps.
what I meant by guess is that the etc is bad. Not regarding the testing. And to test fuel pressure you need an adapter for Honda and its about $230 for the adapter.
Old Nov 23, 2023 | 02:11 PM
  #20
Look at the ECT with a scan tool.
Ground the wire going to the ECT. Does the reading change. Should go to full hot or full cold.
