High temperature indicator
I have a 2016 Honda Fit. I’ve noticed for the first time that the High Temperature Indicator blinks red when the car is parked and the motor off. Is that normal, or have I got a problem? Thanks.
welcome to the forum. hope this helps https://www.700r4transmissionhq.com/...lly%20overheat. when the engine is cold, check all radiator fluid levels including the plastic overflow container.
| All times are GMT -5. The time now is 06:50 AM. |
