Please help asap
My 2008 Honda Fit worked great all day today but when I pulled into my driveway it decided not to shift into park. Eventually after trying to reverse and drive my break stuck. I tried keeping it in neutral with the E brake on and turning the engine off which made it basically completely shut down. The radio now needs a code, my battery seems to be dead, it qont turn over, yet all my lights are still working , and I still cannot get into park. Please help!
welcome to the forum. When you purchased the Fit, you should have received the radio code on a card. if not, go to a honda dealer and they will get it for you. make sure you have the registration and your id with you. clean your battery terminals, not just look clean. you are stepping on the brake pedal to put the shifter into park yes.
Yes I am. And I have the code.
still having problems shifting into park after the terminals are cleaned and brakes held down?
| All times are GMT -5. The time now is 06:54 AM. |
