What happens if I go over the tounge weight capacity
My hitch has a tough weight of 200lbs but I found one website that says the civics max tounge weight is 100lbs. What harm will it do if I got over it 20/50 lbs?
If you overload the gross axle weight rating, it will cause the tires to misalign, making them wear out faster. It can also case suspension failures if you hit a bad bump really hard, and it can make the car less stable to drive. It will also cause the suspension to bottom out much more easily than usual, and I'm sure I don't have to tell you that a suspension spring is much softer than a bump stop.
