-   -   00 Honda Accord 4 door master window switch ? (https://hondaforum.com/forum/general-tech-help-37/00-honda-accord-4-door-master-window-switch-18011/)
00Aspoon Dec 30, 2025 02:25 PM
Hello team, I have a 2000 Honda Accord. I’ve replaced the master window switch after recently changing the battery and doing some minor repairs and the switch no longer controls the other three windows on the vehicle I’ve done the Honda reset sequence multiple times I have no codes what could be the possible issue fuses are all good by the way
each window works with its own switch
grcauto Jan 2, 2026 07:49 PM
It's a grounding issue. Possibly in the wire loom between the door and A Pillar. They get worked every time the door is open and closed and they break in the insulation.
