01 Odyssey Question
I bought the following stereo from BestBuy and installed it successfully. However, I'm not sure which wire from the car I need to connect to my harness in order to send the signal from the remote on the steering while into the stereo I recently installed.
If anything is unclear, please tell me, I'd be happy to tell you so I can resolve this issue. Thanks |
did you look on the bottom of the radio ??? http://www.amazon.com/gp/customer-me...&totalImages=5
Originally Posted by lowlife9
(Post 20072)
did you purchase a separate wiring harness specifically for your car or are you using the harness that came with the stereo because the ones made for your car should be color matched nor need splicing at all it should be plug and play. you can also search the internet for wiring schematics or contact a honda dealer.
(Post 20075)
Thanks for the help |
i searched a little for some wiring diagrams to no avail but i know for a fact there out there.
(Post 20095)
You might check with places that install custom radios,they may be able to help,I'm sure they have run into this problem.
You need to buy a separate harness that only controls the steering buttons with aftermarket radio
Originally Posted by Acrdr
(Post 20581)
