-   -   1994 Accord with Rough idle/Running Rich (https://hondaforum.com/forum/general-tech-help-37/1994-accord-rough-idle-running-rich-2604/)
StevieD03 Jun 13, 2008 01:17 PM
I have a1994 Honda Accord DX with is currentley idle rough and running rich. It was running fine one minute the suddenly began losing power and felt as it was misfiring
I have done the following.
Replace Cap and Rotor
Replaced Plugs
Replaced Wires
Checked timing (OK)
Checked spark to all four plugs (All OK)
Checked Compression (All cylinders 185 plus)
With the engine running I can pull Cylinder one's and fourplug wire off and nothing seems to chane with respect to how the car runs. Symptoms remain the same.
When I pull plug wires for cylinder 3 & 4 there is a noticeable difference.
Can someone lead me in which direction to go next?
Thanks
acmech52 Jun 13, 2008 02:04 PM
RE: 1994 Accord with Rough idle/Running Rich
welcome to the forum StevieD03: enjoy your stay. check your fuel pressure regulator. leakingvaccum line, faulty pvc valve.
