myheadhertz |
06-05-2018 10:03 AM |
1995 Accord Cooling Fan relay buzzing. I知 in over my head.
Several months back my cooling fan quit working. I tried to diagnose it by swapping the relays in the fuse box. Nothing. So I pulled the connector off the thermal switch and jumpered the connector. Bingo. Next problem was that the fans wouldn稚 shut off until I pulled the fuse. But I was still overheating. I kind of gave up there. Except, I had to move it a few times and forgot about the fan not shutting off. Killed my battery a few times and had to recharge it. Now I知 in a pinch and I have to get this car running. Last time I started it I swear I pulled the fuse and stuck it back in but I could be wrong. Battery is dead. As soon as I plug my charger in the fans are running. And if I pull my jumper out the relay starts buzzing like crazy. And even without he jumper, the fans run no matter what. I知 hoping the relay buzzing is just because of a low battery and when it gets done charging it won稚 be an issue, but outside of that I知 going nuts trying to figure this out. Any advice?
