1996 Honda Accord 4-cyl Engine Cooling Fans
My Engine cooling fans stopped working recently but when I turn the a/c on, both fans run and cycle on and off with the A/C.
Any suggestions? Thanks Tom |
RE: 1996 Honda Accord 4-cyl Engine Cooling Fans
welcome to the forum tfersti; enjoy your stay, your water temp sensor may be not working, when the temp gets to about 210, the temp sensor will open to allow power to the cooling fan to go on to cool the radiator water. known that both fans are working, if you idle your engine and watch your water temp,it should go on when it gets about 3/4 of the scale toward the red line. if the fan does not go on, the temp sensor is most likely not working
