2000 Accord Auto trans/swap in 5 speed??
Old Jul 13, 2011 | 02:53 PM
Accord00's Avatar
Default 2000 Accord Auto trans/swap in 5 speed??
I have a wrecked 2000 Accord with 5 speed, and I have a 2000 accord with an auto trans leaking at the cv shaft seals. Both cars have same 4 cyl engine. How do-able is the swap out of the auto trans and in with the 5 Speed? Are the parts in place of the auto car to add the pedals and such? Thanks much
Old Jul 15, 2011 | 10:59 AM
These are some of the items you will need ,the transmission itself
the ECU from the donor car
the shift linkage and shifter box
the clutch master cylinder and resevoir from the firewall
the pedal assembly with 3 pedals
the piping for the hydraulic system that actuates the clutch
the slave cylinder that actuates the clutch on the manual trans.
you may also need the axles from the donor car, if the bell housing of
the manual trans is a different shape.
Good Luck,Bobby
Old Aug 5, 2011 | 07:10 AM
ravikigul7's Avatar
Yeah . Alteration is good for your vehicle . Try to change it soon . I Suggest you to try vicky.in car accessories online shopping . ITs very good shopping website .Am also using this shopping site.
Tata Nano
Old Aug 7, 2011 | 09:26 AM
sureshsk's Avatar
Default About honda
All honda cars have excellent look and design
but very low in mielage.
___________
busniess cards
hokietiger
Feb 11, 2015 03:15 AM
Donkeydawn11
Mar 13, 2012 11:11 AM
mike0094
Dec 1, 2008 06:34 PM
edwardbowden
Jan 27, 2008 10:03 PM
rodallg
Nov 26, 2006 10:09 PM
