2000 Accord EX check engine light flashing
Old 04-17-2019, 07:12 AM
MDPret's Avatar
Default 2000 Accord EX check engine light flashing
We just replaced the O2 sensor, and now the check engine light flashes at me, it shudders while accelerating and at times while cruising. When I'm in D3, it doesn't shudder, but in D4 it does. Help!
Old 04-17-2019, 02:23 PM
Aftermarket or original Honda part?
Old 04-17-2019, 02:36 PM
MDPret's Avatar
It’s a Denso O2 sensor.
Old 04-17-2019, 07:16 PM
Denso is good maker of O2 sensors
Did you scan and read trouble code?
Flashing check engine light means danger of damage (engine, tranny, cat, etc)
Old 04-17-2019, 07:19 PM
MDPret's Avatar
it’s throwing P0132
Old 04-18-2019, 05:38 PM
Bank 1, Sensor 1 has high voltage
That is what the code says. Something like this requires looking into the circuit
Put a meter on the O2 sensor. Verify the circuit is high. Then go about looking for a short.
Follow the wire from the O2 sensor. See if it is rubbing against anything.
Good luck
Old 04-20-2019, 07:09 PM
Also make sure the O2 sensor connection is tight and not crimped. Look for broken wire.
Old 04-26-2019, 08:26 PM
need to know as avisitor asked, if the 02 sensor is Honda or aftermarket. aftermarket will fail within 30days of installation. Honda's denso 02 sensor is made different from the aftermarket. if it is Honda original, then do the trouble shooting (advised above. ( same with Honda only auto trans fluid, if aftermarket, your trans will start to give you problems )
parts_per_million
01-28-2020 06:41 PM
Harving
07-05-2015 01:03 AM
logantherock
08-05-2010 09:49 PM
samuel_gatech
11-04-2009 04:46 AM
BOUNTY
12-23-2007 08:46 AM
Quick Reply: 2000 Accord EX check engine light flashing
