-   -   2000 Honda civic hx running problems... (https://hondaforum.com/forum/general-tech-help-37/2000-honda-civic-hx-running-problems-11163/)
robertj Jan 12, 2016 03:04 PM
My wife drove her 2000 Honda civic hx home from work. 2 hrs later she goes back out to it. It cranks for a couple seconds then dies. If you try to give it gas it dies quicker. So far i have put on a new fuel filter, fuel pump, injectors, new distributor, new plugs, cleaned out the throttle body, and replaced the map sensor. Any ideas on what else it could be?
bucwheat Jan 12, 2016 05:20 PM
Welcome in,looks like you covered most everything,timing belt possibly.
ATLjunkcars Jan 14, 2016 04:34 PM
You should have someone do a pressure test.
bucwheat Jan 15, 2016 04:43 PM
Yea,compression test would tell if you might have a blown head gasket.
