-   -   2001 Civic head gasket (https://hondaforum.com/forum/general-tech-help-37/2001-civic-head-gasket-5208/)
jmurphnd Nov 28, 2009 09:30 AM
Mechanic told my wife her 2001 Civic was in need of a new head gasket. Not being mechanically inclined I did a little research and it doesn't look like a very time consuming or expensive job. (Pull spark plug boots,remove bolts, remove cover and gasket, clean surfaces, replace gaskets, bolt cover, replace boots. can anyone tell me what such a job should cost. Don't want to get "taken over the hill" Thank you in advance.
acmech52 Nov 28, 2009 09:38 AM
repair shop approx 750.00 dealer a bit higher due to labor this incl timing belt,water pump, anti-freeze, oil and filter, headgasket, crank and cam seals. (EST) If you get yourself a shop service manual, it will help you to do the job yourself.
jmurphnd Nov 28, 2009 02:38 PM
Head gasket
I'm inquiring about the head gasket. Not the timing belt, water pump. etc.
