2001 civic lx ECU/Link Erros problem.
my 2001 civic has the check engine light on. I tried using a scanner to check the codes to see what the problem was. Every scanner i used said link error. My mechanic said it could be the ECU that went bad. I bought a new ECU and made sure the numbers matched the old one and when I tried to get it programmed it didn't work. They said I might need to replace the antenna and ignition tumbler to match the new ECU? Is this true? Did I even have to replace the ECU in the first place? I am really lost and any help would be greatly appreciated.
Thanks |
no the ecu reads the key changing the tumbler won't help.
if you get a new ecu u need the keys that go with it but your ecu might be ok it could be the wire harness. there could be a bad wire or connection between the hook up for the code reader and the ecu
I owned 2001 honda civic lx recently.I got ignition problem,we made computer check up.found that ECU was bad.so if i get second hand ecu what things i have to do,i mean
i can start with old key. |
if you get a new ecu you have to have your keys re-programed at a honda dealer or it won't start.
