2005 Accord , heater issues
I have a 2005 Honda Accord 4dr.
I noticed the other day that the heat does not work. The AC works fine , although when trying to use the heat only cold air comes out. Is this a common issue? Fuse related or could it be the thermometer? New to posting here but always enjoy the tech help. |
welcome to the forum. check your heater valve to see if it is operating, may be stuck. or the cable end came loose.
Welcome.
Thanks !
When I did try it this week I could hear a "creak" sound switching from cold to heat. Is this the heat valve? If so is there a way unclog or loosen the valve ? |
best to change it
