2006 Ridgeline won't start...
Hello all,
For the past month, my Ridgeline has had trouble starting intermittently. It turns over, but fails to start. The battery is new and I installed all new spark plugs. The 'green key' icon flashes when I try to start it---the fob batteries (both keys) are not dead and neither key works :( I apologize in advance for being a novice mechanic. Any insight would be greatly appreciated. Thanks in advance! |
welcome to the forum. may be your ignition switch is going bad, if you carry a lot of weight on the key ring the switch does go bad.
