-   -   2014 Crosstour starting problem (https://hondaforum.com/forum/general-tech-help-37/2014-crosstour-starting-problem-15940/)
ER3idy Mar 26, 2022 01:59 PM
I have a 2014 Honda Crosstour 4WD EXL V6 with 105,000 miles. At about 80,000 miles I would have an occasional problem starting. I would step on the brake and push starter button and it would fail. If I waited a minute and did it again it would start right up. This would happen once every 2 or 3 weeks and then start right up. My mechanic, who I trust, thought I should replace the ignition which I did at 90,000 miles . The issue continues every few weeks. It seems like the issue has something to do with some connection not being made when I step on the brake. Love the car but this issue makes me crazy.
grcauto Mar 26, 2022 06:47 PM
Relay?
avisitor Mar 27, 2022 12:57 AM
Guessing should check the brake switch to see if it is functioning
Personally, would clean battery posts and cable terminals with a wire brush to eliminate corrosion as a possible cause.
ER3idy Mar 27, 2022 09:04 AM
Sorry, what is a bark switch?
grcauto Mar 27, 2022 04:31 PM
Start button.
avisitor Mar 28, 2022 01:48 AM
Sorry, I meant brake switch. You might find the switch is faulty??
Cam and crank sensors are next suspects.
Do a visual inspection of wiring
Sometime you might catch a problem with the wiring??
ER3idy Mar 28, 2022 07:49 AM
Ok, thank you.
