-   -   2014 Honda CRV with code p0341 (https://hondaforum.com/forum/general-tech-help-37/2014-honda-crv-code-p0341-17849/)
MrTracker May 8, 2025 04:07 PM
hi, I have a 2014 Honda CRV with code p0341. Have some troubleshooting planned but thought I would check here first before spending my cash on those.Common Causes of P0341 Code
#1 Faulty Camshaft Position Sensor: The sensor itself may be damaged or malfunctioning. - replace the sensors
#2 Timing Chain or Belt Issues: If the timing chain has stretched or skipped a tooth, it can cause misalignment. - view the timing chain for stretching.
NOTE from AI: P0341 points to the intake camshaft position sensor circuit. The sensor itself is a prime suspect and a common fix, but don't rule out wiring or, less commonly, a mechanical timing issue.
Any others I should get the tech to check on Monday? thanks!
https://cimg0.ibsrv.net/gimg/hondafo...1933c8e116.jpg
https://cimg1.ibsrv.net/gimg/hondafo...6c4eac0ee9.jpg
https://cimg3.ibsrv.net/gimg/hondafo...b917d00fae.jpg
