2022 Insight ATF type and capacity
Bought a 2022 Insight EX about 3 months ago. Needed a high gas mileage vehicle. I have a long distance commute.
I decided to change the oil at 6K miles. I mistook the CVT drain plug for the oil pan drain plug. I saw the fluid was red and screwed the plug immediately back in. I estimate that I lost about 3-4 oz of ATF. 1. I don't expect that I can simply top it off since there's no ATF dip stick. So I need to fully drain and add the fluid anew. Correct? 2. Is the correct ATF for the 2022 Honda Insight EX with e-CVT HCF-2 ? 3. What is the CVT ATF fluid capacity? Thank you in advance. |
