91 accord main relay help
Old Aug 27, 2007 | 01:51 PM
stegmo2's Avatar
Default 91 accord main relay help
replaced plugs rotor and cap. main relay is intermittent on bench test, will that cause the engine to run rough. with fuel pressure gauge hooked up, sometimes it would not show pressure when the key was turned on after on/off cycles it would come on so i would think relay is bad. when it came on, the gauge said the pressure was good? i jumpered the 5 and 7tocheck fuel output and it wasa strong stream. any ideas as to what to check next? Itis running rough with no power. If it idles it goes up and down for a while and then dies. Checked tps and map sensor both were ok.Does the main relay send any info back to the computer that would affect the rough running condition.
Old Aug 27, 2007 | 01:54 PM
stegmo2's Avatar
Default RE: 91 accord main relay help
forgot to say took igniter out and had it tested at advance. Ran test 4 times all 4 times tested good.
HELP
Old Aug 27, 2007 | 07:41 PM
Dongss's Avatar
Sounds like you already found the problem.
The main relay controls the voltage to the fuel pump, which if it loses voltage then a drop in fuel pressure will cause starting or idle problems.
Change the main relay, let us know if it corrected your issue.
Dongss
Old Aug 29, 2007 | 08:19 AM
stegmo2's Avatar
I jumpered the fuel pump to make itand made it come on, the fuel pressure was 32 but it still ran rough. Does the main relay put any other signal to the computer?
lp284
Nov 8, 2010 12:36 AM
Utilityman54
Nov 7, 2009 02:46 AM
HeavyD
Dec 11, 2008 03:59 PM
ROBY17233
Aug 29, 2007 06:20 PM
BigDan
Jul 31, 2006 11:22 PM
