92 Civic No Spark or Fuel
Hi, I am new to this forum and hope that someone out there can help me figure out my problem...
I have a 92 Civic that wont start; I have no spark and no fuel... I checked all the fuses under the dash (all good) and under the hood (seem to be good as well). I replaced the distributor and same problem, I will try the ecu.. If this doesn't work I have no other clue of what to check... Has anyone come across a problem like this, I can use any and all help. Thanks |
check ur timing
welcome ot the forum.. it could very well be the timing it could also be a spark plug that has been tightened down too tight or has loosened up over time( i just recently had that happen to me)
Thanks for the help...
I check timing and all was good... I checked the main relay and re-soldiered the all soldier joints and replaced the ECU.. After that I heard fuel pump power right up but the starter seemed to be freaking out so I took that apart and cleaned it.. All is well now, starts right up like a champ.. Thanks |
glad u got it fixed
i think for this problem you can go to the experts and take some suggestion.that will be a wise decision.
