93 Accord Intermittent Run Problem
I'm having an intermittent run problem with my 93 Accord that has stranded my daughter several times. The car just quits as she is driving down the road. It will turn over but not recrank when this occurs. The fuel pump is working when this happens. After letting the car sit for a while it will recrank. Ignition module or other ideas to check? Thanks.
RE: 93 Accord Intermittent Run Problem
possible fuel filter if not changed, distributor cap or rotor, ignition module,worn plugs, main relay going bad/dirty, or ecu.
| All times are GMT -5. The time now is 03:44 AM. |
