93 honda accord sputters on acceleration
ok my 93 honda accord automatic transmission after the car is warmed up will sputter real bad in order for me to drive in stop and go traffic or at traffic lights i must shift the car as if it were a manual otherwise it will stall.
i have replaced: distributer fuel filter fuel pump fuel pressure regulator and all 4 injectors any ideas |
another addition once warm it wants to idle real low around 500-600rpm gota give gas to keep from stalling
welcome to the forum. Clean you idle cut off (ico) if valves not adjusted for a long time, adjust valves also.
were would i find that
go to hondaautomotiveparts.com and put your car info and look at intake, it will show you the idle cut off.
| All times are GMT -5. The time now is 09:05 AM. |
