94 Integra GSR
Old Jun 27, 2011 | 08:12 AM
greddyrcng's Avatar
Default 94 Integra GSR
Ok i have a 94 Integra GSR and i am needing to replace the TPS sensor from what i can tell this thing is riveted in is this true?
Old Jun 27, 2011 | 08:26 AM
Welcome to the forum,yes it is true ,what you can do is use a cut off wheel to cut a slot into the bolt deep enough to get a screwdriver into. Here is a site I found that will help you change it out,good luck,Bobby http://www.iapdirect.com/pictures/TP...structions.pdf
Old Jun 28, 2011 | 07:04 AM
greddyrcng's Avatar
ok new question.....Thanks for the welcome......I have checked all the vacuums and replaced the TPS sensor all that good jazz and this thing still idles up to about 2000 and wont drop for a while what is going on??
Old Jun 28, 2011 | 10:03 AM
I'm sure you adjusted the Idle air flow screw on the throttlebody,try cleaning the FITV. Fast idle thermo valve.
atrain33
Aug 4, 2011 07:05 PM
98S/C
Jul 2, 2007 05:16 PM
98S/C
Jun 12, 2007 01:11 PM
patrickbryan85
Mar 16, 2007 09:49 PM
tegsr
May 9, 2006 09:33 PM
