95 Honda Civic Overheating???
Old 09-10-2006 | 08:57 AM
Christlike's Avatar
Default 95 Honda Civic Overheating???
I have a 1995 Honda Civic that just all of a sudden started overheating for no reason. There are no leaks from the radiator or hoses. After the car overheated and cool downed, I topped off the radiator with a 50/50 mixture, but the car still is overheating. Also, there are no water leaks either (i.e. from the water pump). I am not a car expert, but I know a thing or two. What would be anyone's guess as to what is causing this? My only guess is the thermostat? I am able to still drive the car with the heater on full blast, while watching the temperature gage. Also, I haven't had the radiator flushed in years, nor has the thermostat been changed. In addition, the radiator cap looks good without any rust or cracks.
Lastly, just before the radiator overheated, I had the air conditioning running for about 20 minutes. Thanks for anyone's wisdom and knowledge into this thread.
Old 09-11-2006 | 12:40 AM
proff's Avatar
Default RE: 95 Honda Civic Overheating???
water pump or thermostat
Old 09-29-2006 | 11:39 AM
lana's Avatar
Check if your fan is starting to work when it reaches the appropriate temperature. Start the engine, warm it up to the regular working temperature and, if possible, get someone to look at the fan. If it does not start working when the pointer shows regular working temperature, the options might be:
1. thermostat is dead - need to replace
2. wire from thermostat to fan is disconnected - connect and secure with heat resistant tape or simple wire.
If the fan works, check the pump (or, better, if you're not proficient with that, have a mechanic check it).
Have you changed belts regularely?
Hope I've helped
Lana
Old 11-30-2006 | 11:22 AM
Benniehonda's Avatar
Could be a clogged radiator or a headgasket leak between the cylinders,bad thermostat.
scanner737
07-03-2014 12:13 PM
Derbychik03
11-14-2013 07:41 PM
Radiance423
09-30-2013 09:00 AM
Hitron
08-26-2011 01:55 PM
topherhead
01-10-2009 04:19 AM
