96 accord vtech charging or electrical issue?
Hello people I have a issue I hope someone can help with. I have a 96 accord vtech 5spd. Yesterday I was driving and I noticed the gauges were not working and car acted like it wanted to stall a few times so I manage to get it home and shut it off and try to start it and nothing ! Battery is dead. So i clean the cables and get new battery. Today I go to store and leave it running I come out to the gauges not working. So I shut it off and sure enough battery is dead . I get a jump and drive home. Leave it running for about 15 minutes go out and no gauges working radio don't work and heater or wipers don't work but car still running. I shut it off and battery dead again?? I thought maybe alternator but think it wouldn't run with dead battery and bad alternator?.. Please any help will be appreciated. Thanks
Hi
Hello thanks for reply. And yes new battery yesterday after first time it died. An no there is no battery light on.. And haven't had alternator tested. It will run after a jump if I unhook battery it dies. But no batt light
And also after getting home and I shut it off and it acted like batt was dead and wouldn't turn over I came inside for about 1hr went out side and it started right up. Then let it run unhooked battery and it died. Tried to start and no start dead batt. Lol confusing
my experience has been, if the battery is good and I start the engine, and if the alternator is charging, i can disconnect the alternator and the engine will continue to run. if the alternator is not good or weak and the battery is disconnected, the engine will die. Sounds like you need to take the alternator in for a check to see if it charges.
Dagonus
06-02-2014 06:22 PM
Honda Accord
06-22-2013 06:07 AM
