97 accord window questions
Hello im new to the sight but i have a few questions,
1. The front windows some times role up and dound fine and other times its hard 2. wen the car is in acsesory the windows will not roel up at all 3. the driver side window dips forward wen the window is roling up if any one can help me on this id apesiate it oh and both the regulators have been changed and it still doce the same thing:cool: |
welcome to the forum. you may need to take your door panel off and check to see if the window glass is falling off the track, or half of the platform is loose causing the window to tilt going up or down. you can also check to see if there is a bind in the grooves of the window. May need a service manual to see what you are looking at, or go to hondaautomotiveparts.com and put the info and look at the parts, or library has books on hondas
ok thanks ill have to check the library to see if they have a book on the car
