97 Odyssey CV replacement
Old Mar 23, 2012 | 04:06 PM
paulsvail's Avatar
Default 97 Odyssey CV replacement
Hello -- first time post. We have a '97 Odyssey with the front left outer CV boot failing -- throwing lube around. While the boots themselves are only $20, a new transaxle with boots only runs $70. After 200k miles, I'm thinking not only would I have to thoroughly clean the CV to get the grime out now, but doing that job would be a pain compared to 'new' full CV.
How easy is it to get the brakes/rotor and the front suspension elements out of the way to swap out that transaxle? Do I have to take the lower ball joint apart or can it sweep to the side/front and be out of the way enough to do the job with minimal hassle? Any experienced hands here have ideas? Thanks!
Old Mar 26, 2012 | 10:22 AM
Welcome to the forum,these instructions are for an Accord but should help.
Step 1
Jack the vehicle up and support it on jack stands. Remove the both front wheels. Using the 36 mm socket, remove the center axle nut. Remove the though-bolt on the bottom of the strut where it attaches to the spindle.
Step 2
Separate the bottom ball joint from the spindle using the ball joint separator. Using the pry bar, pry the lower control arm down to pull the separated ball joint out of the spindle and push the spindle out of the way toward the rear of the car.
Step 3
Use the pry bar to pry the CV axle out of the transaxle. Put the pry bar between the transaxle case and the CV axle, and push it out. Remove the CV axle and put it in the box the new axle came in---CV axles carry a core fee, which is refundable upon return of the old axle.
Step 4
Install the new CV axle by inserting it into the transaxle up to the snap ring clip where it will stop. With both hands, pull it back about an inch and slam it in with a fast push, and you will feel it snap into the locked position.
Step 5
Grab the brake rotor, pull it outward and insert the outer end of the CV axle into the hub in the rotor. Rotate the rotor back and forth to line up the splines and push the axle in as far as possible. Loosely screw on the axle nut.
Step 6
Pull the lower control arm down with the pry bar. Line the ball joint up with the hole in the spindle and insert the ball joint. Install the nut on top of the ball joint and tighten it down.
Step 7 Install the bolt in the bottom of the strut where it attaches to the spindle and tighten. Torque the axle nut to 180 foot pounds. Put the wheel on and repeat from Step 1 for the other side.
sjv
May 29, 2018 06:02 PM
nomrod
Sep 8, 2014 07:44 PM
scj6771
Jan 11, 2014 03:46 PM
crn1010220
Nov 25, 2012 01:32 AM
davidLX
May 8, 2006 12:27 AM
