88 accord idle issues? {w/ videos}
Old 04-04-2018, 03:12 AM
cjones15's Avatar
Question 88 accord idle issues? {w/ videos}
Hey y'all.
I have a stock 88 Accord, Lxi, 5sp with 108k on her.
A few months ago, while in neutral or at idle, she would die on me. Starts right back up, though.
It was worse for a bit, then got better for awhile. Now it's as bad as ever--happened right after changing my tires? It's like she gets in moods. Following has been done:
new plugs
wires
rotor
bled coolant
cleaned IACV
cleaned FIV
cleaned throttle body
etc.
here are some videos of the issue:
(sound is better-ish after :40)
I'm sure this issue is familiar to a veteran out there. Thanks in advance for the help.
-C
Old 04-07-2018, 11:02 AM
Welcome in,I would have bet money it was a dirty idle air control but you cleaned that,try using throttle body cleaner first if no lmprovement try replacing the idle air control valve.good luck.
wolfbone
03-12-2011 07:47 PM
dinhster
11-01-2010 09:31 PM
96LxAccord
03-23-2010 10:12 AM
Patrick
09-29-2008 04:49 AM
jabax
07-11-2007 12:47 AM
Quick Reply: 88 accord idle issues? {w/ videos}
