98 civic wont start-please help
Old Feb 10, 2010 | 10:48 PM
splat41's Avatar
Default 98 civic wont start-please help
Ok, here goes. This is my kids car. The car started, he went to pull out of a space and his foot slipped off the clutch and it died. Now it wont start.
Heres what I know.
1 Its got spark, checked with a good plug
2 The rotor is spinning telling me the timing belt is still good
3 Its got fuel to the fuel filter, losened the banjo and turned key on, gas squirted out
4 Looking down the plug holes I can smell gas, and saw some on top of the pistons while cranking
5 One cylinder has 60 psi compression, others are all 150... This was dry, all plugs out, ECU fuse NOT pulled, and i did not pull the fuel pump fuse out. And i did not WOT the gas pedal while doing it.
My question is... Could the Timing belt have skipped a tooth or 2 causing it not to start, and bad comprerssion in one cylinder? Please help me, Im pulling my hair out. Anything else I should check?
Old Feb 11, 2010 | 03:16 AM
If the car has over 90k miles, you might look at the belt jumping a tooth or two, check the line up of cam timing marks.
Old Feb 11, 2010 | 07:11 PM
splat41's Avatar
You think that if it slipped a tooth the car would not run at all, and have bad compression in just one cylinder? I hope thats it, you ever seen this before? The car has 150,000 miles, not sure when the last timing belt was done...
Old Feb 12, 2010 | 02:13 AM
slip a tooth will cause a not run. bad compression will cause a rough engine.
Old Mar 12, 2010 | 01:18 PM
tenseconds's Avatar
Default hey
I don't know why it wont start but i do know that the reason why that one cylinder is low in compression is because you have a bad exhaust valve. so you might want to check all you valves, and the timing belts could have slip making the bad valve. I hope this helped you out, and maybe you can get it running again.
Old Mar 16, 2010 | 12:19 AM
LOrangeH22hatch's Avatar
Yeah, i'm with them. Sounds like the belt may have jumped a few teeth.
juiceygen
Mar 16, 2010 12:27 AM
splat41
Feb 10, 2010 11:33 PM
rancherogt1973
Mar 30, 2009 11:26 PM
rancherogt1973
Mar 30, 2009 07:52 PM
lorna
Feb 4, 2007 06:50 PM
