98 honda civic idle problem
Old Aug 31, 2009 | 07:37 PM
jose valencia's Avatar
Default 98 honda civic idle problem
my honda civic idles high then low over and over again.....any suggestions as to what may be causing this problem? I just gave it a tune up and even changed the distributer but the problem continues.
Old Sep 1, 2009 | 02:38 AM
welcome to the forum. If the engine is cold, it would be the idle control valve, if it is warm it can be the throttle positon sensor or the map sensor.
Old Sep 1, 2009 | 07:37 AM
thanks for the help...is this an expensive fix??
Old Sep 1, 2009 | 10:25 PM
91haydenSI's Avatar
Welcome to the forums. no the idle air control valve is fairly cheap and easy to replace.. a map sensor usually goes bad because its dirty and you can clean it with map sensor cleaner and it will be fine for a while..
darkrain777
Feb 20, 2014 02:44 PM
bcole6
Apr 30, 2013 09:30 AM
vitaliy273473
8
Dec 6, 2010 06:29 PM
hugz4me2day
Jul 15, 2010 10:01 AM
babalot999
Jun 3, 2010 12:44 PM
