AC on 08 Odyssey not getting power.
The compressor is not getting power. There is no power going to the relay. Do I need to replace the control unit on the dash? It used to only engage when set at the low setting.
welcome to the forum. did you check to see if the fuse is good. it is possible your ac reostate is worn out,
