air compressors and impact wrenches
Old Oct 1, 2008 | 09:24 AM
rollingthunder6's Avatar
Default air compressors and impact wrenches
how do the spec-s of an air impact wrench relate to the air compressor?
i need to loosen a crankshaft pulley bolt that is torqued at 134 ft-lb. on a 1998 honda civic LX. i have a sears craftsman 1.5hp 4-gallon
4.7SCFM@40psi3.3SCFM@90psi air compressor. i don't yet have an air impact wrench. what should i look for in terms of psi when i go to
buy one, such that i can use that air compressor to drive the impact wrench to loosen the bolt? tia.
Old Oct 1, 2008 | 11:53 AM
Default RE: air compressors and impact wrenches
Welcome to the forum.If you intend to do a lot of garage work, or do painting, a jiter-bug takes 90cfm. A compressor that puts out 80-90cfm is good. this would equate to about 6-7 hp, 32 gal, 150psi storage. Go to Sears and ask the tool dept expert, and he/she can adivse you a lot better. Don't buy until you do some price comparison. get the most cfm. your current compressor will not turn the impack fast enough.
CrossCountryDriver
Aug 29, 2014 10:35 PM
coldufo
Sep 2, 2009 12:12 AM
xmasterx87
Sep 27, 2007 12:34 PM
PacMan
Nov 4, 2006 12:13 AM
PacMan
Nov 2, 2006 04:16 PM
