Any Ideas?? 94 Accord Main Relay prob.
Got a 94 Honda Accord, Main Relay when plugged up clicks (loudly), car will not start, so I bypassed it and when I jump from the batt. to the Fuel pump, wire gets super hot, and boggs the battery down so far that it will not start. But the Jump from the ECU/ Injectors to the battery is good.
I figure if I buy a new relay, it will do the same, because of how hot the jump wire is getting! Got any ideas?? :confused: |
Fixed the problem..... Battery was bad! Which was causing the relay to rapidly open and close the fuel pump circuit.
good find, thanks for the input after fix.
