brake grinding noise
Every month or so, my 2011 CRV makes a grinding sound when applying the brakes.
The sound sounds like the brake pads are cutting through the rotors. There is no scarring on the rotors (all four corners). The pads are good, and I actually pulled the wheels the first time this happened. Once the sound happens it corrects itself and doesnt happen for a few more weeks. I have recently had the transmission fluid changed along with the differential and transfer case. The sound actually led me to having this done, once i checked the brakes and found nothing. I really cannot take the car to a mechanic to hear it, because it happens so infrequently. Has anyone else had this experience. |
welcome to the forum. If you live in an area with high humidity or parked near a sprinkler, the rotors develop a light rust, when the brakes are first applied, it sounds like a grinding sound, then goes away. or if parked for a few days, you might be able to see the bright metal have a brown coat of rust. I live in Hemet ca. was my car on a sat, drive it on a tue and the first application it grinds, then no noise after that.
Originally Posted by acmech52
(Post 28114)
that is why it is so puzzling. |
it is possible that the brake is crazing. take the brake pads off and check to see if there is metal on the pads, sometimes hot brakes gets rotor metal transfer.
(Post 28125)
thanks for the suggestions |
I know on one of my cars it produces a great amount of brake dust which causes squealing and some grabbing. I plan on going to ceramic pads to eleminate this.
I had an issue years ago with my 99 Civic in which there was a small rock stuck between the rotor and the backing plate. I would check for that because, being female and this sound being very random, though terrible, it took me a while to get a mechanic that took me seriously and figured it out.
