A/C specs for Hondas?
Hi all,
I have a 2004 Pilot and would like to know what my low pressure and high pressure ports should read (and at what RPM). Does Honda publish these specs? Thanks in advance for your help, Dig |
welcome to the forum. I got this for a 06 pilot. normal readings on high and low side w/a/c off depending on outside temp is 80-105 psi ( static )
eng rpm 800-100rpms, a/c on high and max low side 25-35 psi. normal high 200-300 psi. vent temp s/b about 42-45 service with engine running. |
| All times are GMT -5. The time now is 10:02 AM. |
