acmech52 |
04-24-2009 12:49 PM |
welcome to the forum. I'm not sure you can put 3ed gen parts to work in a 4th gen car. If you check in hondaautomotiveparts.com by looking up the part numbers of all the parts you want to change over, the part numbers may not match up. Also the part illustrations will show you all the parts you need for the change over. If you are mechanical minded, yes. Also check with autozone.com in repair or component seach and this also will help you to identify parts with diagrams.
