97CL3.0 |
01-04-2010 12:20 PM |
CRAZY SHAKING PROBLEM!!!! Any help?
I have a 1997 Acura CL 3.0. Every now and again it develops a bad shake in it. It feels like the wheels are going to fall off. It can't be even safely driven at 45 mph. Other times its smooth as can be, like it normally should be. Sometimes, the shaking isn't AS violent and it comes and goes away after a few minutes. Everytime it does shake, the brakes shake even worse when they're applied. I've replaced the upper ball joints/control arms on both sides, replaced the shocks/struts at all four corners, I've inspected the strut mounts in the front and they're fine. I've replaced both front hub bearings, and both axle half-shafts. Bottom ball joints appear fine. I plan on replacing inner and outter tie rod ends on both sides today. This is getting expensive and VERY frustrating. I took the car to Honda, and they couldn't find anything wrong. The car has 206K miles, but runs like a champ still (aside from the shaking) so I hate to get rid of it. I NEED HELP!!! I'm pretty mechanically inclined and I cannot figure it out if it's not the tie rod ends - inner or outer....
Curt
