Del Sol - How do I fix my power windows?
All 3 windows stopped working in my 97 Del Sol. I hear a faint clicking coming from behind the middle of the dashboard when I try to open them. Tried replacing the swiches on the driver side and no change. Im out of ideas, can anyone give any suggestions?? I need to fix this to get it to pass state inspection! :-(
I had the same thing happen to my 95 Si 2 days ago. So yes im hoping someone has a solution.
I finally got mine fixed, I believe they said some relays died or something. I had it fixed locally at www.richmondbatteryserviceinc.com. It cost a little more than I would have liked but still cheaper than I expected, something like $140. Im not sure where the part was they fixed but maybe if you talk to them, they could get you to ship the part to them to fix? It was the only solution I could find myself
I got mine fixed! It was not the relay. However there is a 7.5 amp fuse in the fuse box under the dash that say sit is for all manner of things, however the window relay is not one of the things listed. But yep it does indeed provide power to the window relay! So if yours isn't working but you hear the clicking check that 7.5 amp fuse. It may be the source of your issues like it was for me.
