del Sol won't start intermitantly
My '94 del Sol SI will not start once in a while. Cranks fine, but won't fire.
Go back later and it starts right up.(sometimes) Always happens cold. Any ideas? |
spark plugs, wires, compression, relay, ignitor, distributor.
New wires and plugs.Good compression. What relay? Ignitor? What's that? New name for the ignition coil?
Wondering if it could be a fuel issue. |
main relay, and yes ignition coil. and yes could be fuel, check your fuel rail to see what pressure you have if any.
Boy, is my face red!
Frozen fuel line! Drygas solved the problem. Never had a problem with this in 30+ years!
might be all the junk they are putting in the fuel, or lots of moisture getting into the tank. Thanks for the find and fix.
