Electrical Problem
ok so my alternator is not charging my battery. Went and had alternator tested twice and the alternator is fine. I pulled the ground cable off the battery when the car was running and the car died instantly. I checked the plug that goes into the alt. and that is fine and clean. I dont know what else to check and am completely stumped. its a h22a in a 96 civic coupe btw.
welcome to the forum. Did you check the condition of your battery while you tested the alternator. have you done a load test to prove the battery is good.
Electrical Problem
I have a problem with my car, my brake lights doesnt work. I checked the bulbs, fuses relays and brake switch. it seems to be working fine. what is the problem? any experience?Thanks for your help. _______=== XRumer 5.0 Palladium RULEZ! ===
check for good ground.
Electrical Problem
I got the same problem, after a month...but I charged it the opposite way....I mean through the mains, when it was there for 4 hrs and still not going to get turned on I tried the usb cable, PC found there is nokia on USB, but PC Suite found nothing this time. Display dead. Going to ask for replacement.
Igorokk welcome to the forum, what are you talking about? Please explain how a USB with nokia is going to help fix a none charging alternator on a honda??? Thank you
