is it an good idea to flush transmission as recommended by dealer
Old Jul 18, 2013 | 08:24 PM
BlueMike Llewellyn's Avatar
Default is it an good idea to flush transmission as recommended by dealer
what are people views on transmission flushes
Old Jul 19, 2013 | 07:51 AM
Most people think they do more harm than good,I don't think that manufacturers would build these machines if they didn't work. I prefer to drop the pan and inspect,replace the filter and gasket and be done with it.
Old Jul 19, 2013 | 10:25 AM
welcome to the forum. When I had my trans overhauled, the owner stated that if every person who owned an automatic trans changed their fluid once a year, most auto trans shops would be closed up. I change mine each 30k on my 07 Fit, auto.
Old Jul 19, 2013 | 04:02 PM
lowlife9's Avatar
i believe that honda actually doesn't recommend you machine flush there transmission's but since alot of the newer hondas have a non servicable internal mesh filter instead of a easy to replace external filter it would probably be wise to have it machine flushed once or twice with a drain and fill every oil change or 5,000 miles. they do make after market external filter kits along with transmission coolers that would greatly enhance the reliability of the transmission.
Old Jul 20, 2013 | 04:40 AM
GilbertF's Avatar
Member
Hi, You need your car flush if you are facing following problems:
1). Transmission Grinding or Noises
2). Problems Shifting Gears
3). Delay in the car Movement
Otherwise you need not to go for flush. It may cause you replace some other parts also. So analyze your car problem and then go for it.
Old Jul 22, 2013 | 04:43 AM
Dorisscott's Avatar
Hi, It's total wastage of time and money. Can you tell me what's the problem with your car?
Old Jul 22, 2013 | 09:01 AM
I disagree,my Accord had problems going into reverse several years ago,My wife brought it to our mechanic ,he flushed the trans and no more problems. As Lowlife says these cars don't always have filters that can be changed and the flush is the way to go.
bucwheat
May 6, 2009 02:53 PM
rd_way
Mar 2, 2009 05:28 PM
desperado
Jan 29, 2009 07:59 PM
akamina 2005
Oct 31, 2008 04:30 AM
RayGun
Dec 5, 2006 05:20 AM
