Headlight Issue
Thanks for the ad! My daughters 2005 CR-V repeatedly burns out the drivers side headlight. The bulb seems a little loose when I install it in the socket but not super sloppy. Could this be the problem or should I look at something else?:confused::confused::confused::confused:
The socket may be grounding out,you can wire in a new socket pretty easy.
Thank You for the tip. That is where I was headed but wanted confirmation. Ordered two today from my dealer for $23 Canadian each.
