help driverside floor leak
i have a 2000 honda civic coupe and i have water soaking the floor due to this heavy rain in florida atm so i had to put it in the garage.. ive taken off the driverside fender and sealed the gromet that runs wires from the door to the body.. taken off the cowl and that all looks fine.. btw i do not have a sunroof.. i did have the windshield replace a month after i bought the car which was in march. the water seems to be coming from behind the hood release cable but above the gromet of wires from the door.. i can even hear the drips when it comes down and theres a trail of it just sliding down after it hits the sponge where the gromet goes.. any help would be greatly appreciated all i can think is that they didnt seat the windshield right
i'm gonna grab my camera and take some pictures of it now
2 Attachment(s)
heres 2 pics one it shows where its dripping and even sliding down the side and the other is the area its coming from but above the sponge and wire gromet
its most likely coming from a bad seal on the windshield if thats the case it should have a warranty for leaking from the shop that installed the window take it up with them. alot of people don't realise the importance of a properly installed windshield. the windshield actually reinforces the roof in a roll over.
Originally Posted by lowlife9
(Post 18606)
he came out and did another air hose check and even sprayed window cleaner on the windshield to see if it would bubble up which it didnt.. so i sprayed the car while he looked under the dash in the area and he saw the leak. its coming from the gromet area where that little sponge is. theres a gap there.. is there supposed to be a gromet on the inside of the car that closes the sponge in?
I don't see a sponge in the pictures,a grommet is used to fill a hole where wires run from the cab to engine bay it should stop water from comming in but try squeezing a dab of silicone in the hole .
Originally Posted by bucwheat
(Post 18611)
http://www.2carpros.com/questions/ho...water-in-floor |
3 Attachment(s)
heres some pics and you can see where the gromet goes into the body and the sponge behind it.. its coming from above that area i'm hoping the bendy straw up the oval area with some sealant might do the trick any input would be appreciated as im literally close enough to banging my head into a wall
looks like the previous owner went to town with silicone trying to stop the leak. obviously the car didn't come stock with a sponge stuffed in there i would devise a way to completely seal that broken gromet at least it looks broken anyway seal that bitch up.
| All times are GMT -5. The time now is 09:56 AM. |
