HELP! Engine overheating problem???
Here i am posting the problem that I'm facing with my car from last 2 month. My car engine overheats quickly only in small run. I'm unable to understand what's the problem is? Is it a big issue and i need a machanic or it can be solved by myself. I'd already spent so much money on my car and don't want to spend more. So please give me your suggestion that what i have to do!!! :confused:
Start with a new cap if no help then try a new thermostst,and if not solved try having the radiator boiled out.
Originally Posted by bucwheat
(Post 20993)
Make sure the thermostat is not in backwards. are the hoses in good condition,a pinched hose due to vaccum can cause overheating.
(Post 21018)
what have you done to fix the overheating to date. have you checked your timing. if retarded it will run hot. did you put in a used or rebuilt, or new radiator. is your radiator fan working when it gets hot.
Originally Posted by GilbertF
(Post 21023)
Thanks! Yes, I think that there are some problem(like pinches) with rigid tubes. Now how can i solved this problem?:confused:
This problem occurs when the engine parts get old or damaged. You can go through http://www.360tuners.com/engine-performance-parts.aspx and you can replace your car's mostly damaged engine parts and thus get your problem easily solved.
Hey, I recommend you to go some local manufacture, during online shopping there may be problems like you can only check products after shipped & payment and if u go for local manf. you can check the product before purchase and if the product is damaged or not suitable; you can easily get replaced it at the spot. On the other side it may take your lot of time to do all this.
Helpful information.
Thanks Everybody! |
