Honda Accord Idle Problem
Old Oct 31, 2012 | 09:26 AM
Carmen's Avatar
Default Honda Accord Idle Problem
I have a very high milage 92 honda accord. This past summer i started having a problem.
The car starts, idles fine and drives fine. After it warms up though it idles very rough and the hotter the day time temp. the worse it idles. It also smells bad when I park and turn off engine. It does not idle near as rough on a cool days or not rough at all.
Also now the car at idle (when warmed up) has pulsating rpm's. Idles high and low, high and low but goes away if I put in gear or turn on air cond.
Looked in a repair book could be a variety of things. I can't find a vacuum leak that I can readily see. Got any ideas where to start.
Old Oct 31, 2012 | 11:44 AM
welcome to the forum. Check your egr vlv. this is tied in with your exhaust sys. gets a lot of carbon.
Old Oct 31, 2012 | 11:18 PM
lowlife9's Avatar
clean out you IACV or idle air control valve a dirty iacv will cause erratic idling.
bcole6
Apr 30, 2013 09:30 AM
colbygfp
Oct 12, 2008 06:39 PM
RotnikVW
Feb 28, 2007 01:55 AM
alexk
Feb 1, 2007 11:24 PM
BigDan
Jul 25, 2006 12:22 AM
