Idle issues
I have a 97 honda accord DX with automatic transmission. I had the trans replaced and rebuild the motor. Everything was fine but then the car would rev in park and neutral. It also idles around 1200 rpms. I have replaced the Idle Air Control Valve and bleed the coolant. I have a new intake gasket on the way. I also took off the battery for an hour to clear any ECU memory just in case. If the gasket doesn’t fix it how would I test for a vacuumed leak? Also is there any more things I could see if it is the problem.
It was kind of included in the other stuff I had done. I had the carb rebuilt, fuel tank dropped, flushed and pressure tested and then after that, it still wasn't idling right. That's when we discovered that the AC Diaphragm Set was bad. I ordered from the place in Japan and got it in a week. Actually it shipped on Monday, received on Wednesday. My car anyway, has a spaghetti of vacuum hoses so if yours does too, it could be a vacuum hose leak from anything. A good mechanic should be able to track it down and at least give you an estimate of costs. You may be able to do the repairs yourself.
